| Message |
rolling at some speed, you push the clutch in, and the motor goes to idle and dies. If you're missing any of the oem plastic shields, forward of the radiator, they should be reinstalled. Without doing the full flowerpot mod, you can test this problem by placing a srip or two of duct tape, lengthwise along the side of the filter, that faces the front of the car. You should also check your tps and maybe check for vacuum leaks.
